Compact Field Point with Touch Panel
Hi.
Have anyone designed a NI Compact Field Point or Compact RIO with a connected Touch Panel Monitor?
I have an instrument with RS232 output (serial data). Since I am using LabVIEW 8,
the executed application should run in Embedded WinXP. But, I need a touch panel for control and monitoring.
I would appreciate any advise please.
Thanks in advance.
Bon
(3,151 Views)
Hey Bon,
What kind of information are you looking for? NI sells a TPC 2006 device which is a touch panel and runs windows CE. This device can be programmed using LabVIEW PDA. This device has a Ethernet port so that you can also communicate to the cRIO or the cFP. Is this what you are looking to do? You can call in on (888) 280-7645 and a sales person would be able to understand your application much better and advise you accordingly.
Chetan K
Application Engineering
NI
(3,123 Views)
