Compact Fieldpoint TCP/IP remote port
i am working on cFP 2120 / cFP 2020 and for TCP/IP connection i have to use remote port number. so can all you guide me that what remote port nu. or service name i have to use.
waiting for your reply
Prashant Soni
LabVIEW Engineer
(2,959 Views)
The port number can be whatever you want it to be, as long as the server and the client have the same one specified. Generally, you have a server publishing data to a port and some client reading data on that port. I believe there is a TCP communication example in the Example Finder, just search for TCP and look for TCP Communication.lvproj. It's actually set up with a real-time target as well.
Good luck!
Misha
(2,939 Views)
