Compact RIO Error log.
  I just reformatted the Compact RIO and installed the applications by  booting up the RIO in Safe Mode and click format disk in Mesurments and Automation explorer.  After that, I gave new IP address and installed the software by Add/Remove software in Mesurments and Automation explorer.      If I click on the view error log in Mesurments and Automaton explorer, I get
#Date: MON, MAY 19, 2008 04:07:28 AM
#OSName: VxWorks
#OSVers: 6.3
#AppName: /c/ni-rt/system/lvrt.out
#Version: 8.5.1
#AppKind: AppLib
this message everytime I boot up the RIO.
Is there any problem with my RIO?
Thank you so much for all your help.
(3,347 Views)
hinewwiner,
The text you pasted in here from the error log is the header of the log file.  If there were something wrong with the cRIO there would be additional information beneath this header.
You should be good to go!
Jared Boothe
Staff Hardware Engineer
(3,326 Views)
Ohh. Thank you so much.!
(3,322 Views)
You bet!  My pleasure!
Jared Boothe
(3,310 Views)
