Compact RIO Standalone RT Application with Internet access
I am currently working on a Compact RIO and would like to deploy the VI as a standalone application to run independantly on the Compact RIO without the need for a host computer. Apart from that, the Compact RIO also has to have internet access. I have a CRIO 9022 and am unsure how to set up internet access for it as well. Should the Ethernet cable be plugged into Socket 1 or Socket 2? The other end of the ethernet cable is connected to a switch with internet access enabled.
Please Help
(3,005 Views)
If you're looking for the cRIO to sit just on an ethernet port with internet access then I'd recommend using Ethernet Port 1 either with DHCP or a static IP that isn't in use by your network.
(2,997 Views)
Hi
Thanks for your reply. After we set up the Compact RIO to run st startup with a real time application, what other settings do we have to configure to allow it to have internet access? The IP address is static. Also, we would like to have a remote front panel service running in order to view the front panel from a remote browser to monitor our system. Would it be possible to provide me with some step by step instructions of setting this up? I tried the steps from the guides at National Instruments website but all of them require the presence of a host computer, whereas we are building a real time application.
(2,994 Views)
