Compact Rio
I connect my Compact rio controller to the PC through Ethernet (Lab) cable and power is set. But, I can't detect my NI- Compact rio device in the Remote systems of the MAX. And also the status LED doesn't lit.
(2,751 Views)
Hi Maniraj,
did you read the user manual?
- Did you install any software on your cRIO?
- Did you install needed software on your PC?
- Does its IP settings match your computers IP address? (There's a sentence in the manual about asking your (network) admin!)
(2,740 Views)
