CompactRIO ローカルフォルダーへのアクセス
NIのMAXを使用してCompactRIOのローカルフォルダーにアクセスしようとすると、
ブラウザーが立ち上がってしまします。
エクスプローラーでフォルダーを開く方法をご教授お願いいたします。
(857 Views)
Accepted by topic author Y.Yamazaki
@Y.Yamazaki wrote:
When trying to access a local folder on CompactRIO using NI's MAX,
The browser will start up.
Please tell me how to open the folder in Explorer.
To open the file in Windows File Explorer, you need to install FTP server. See Using FTP With an NI Linux Real-Time Target
However, FTP is not secure and is not recommended. If you are using the legacy installation, use WebDAV. See Monitoring and Configuring a Remote Device from a Web Browser
If you are using the NI Linux RT System Image installation, SFTP is enabled by default. Use FileZilla to access the remote files. See Tools Available for File Transfer/Access on NI Linux Real-Time Targets
https://tmesystems.net/
(808 Views)
Dear  ZYOng,
I hope this email finds you well.
I would like to express my sincere gratitude for your prompt response and assistance.
Upon installing the FTP server, the issue has been successfully resolved.
Your precise advice was truly invaluable and greatly appreciated.
Thank you once again for your support.
Y.Yamazaki
(787 Views)
