CompactRio With NI 9233 RS-232 Serial Port Questions
Hi guys, I have successfully completed 80% of my project with the help of everyone here, now that i have to move on to CompactRIO w/ a NI 9233 Module, i would like to actually use FPGA to run my VI in real time condition without the need of a computer, my question is when i am using RS-232 Serial Port, i actually use VISA serial/read/write, but now i would like to use the RS-232 port on the compactRIO to actually receive data from external source...
How do i do that? Is it the same as what i have done previously? Do i need any major restructuring? I have tried example finder on both my LABView 8.5 and on this website, but i can't find anything relevant... It's either there isn't any, or i'm not searching properly. Any help would be very much appreciated!
Thanks in advance.
Message Edited by Simmy on 07-09-2008 01:44 PM
(2,908 Views)
can someone please help me?
(2,872 Views)
Hi Simmy,
You will need to install the NI-Serial driver, along with NI-VISA, on your cRIO for this to work, but otherwise it should act similarly to when you are running the vi from your computer.
The drivers shoud be available at http://joule.ni.com/nidu/cds/fn/p/sn/n23:3
Hope this helps.
Stephen S.
Applications Engineering
(2,850 Views)
Thanks for the help, i will try it out, will revert back if there is any problem, thanks alot.
(2,841 Views)
