Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Compare 2 string's -> output boolean
rutekp
Member
12-22-2003
08:36 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Is there any simple way to compare two strings. The output should be true or
false.
rutekp
0
Kudos
Message
1
of 2
(3,353 Views)
Reply
Re: Compare 2 string's -> output boolean
Mads
Trusted Enthusiast
12-22-2003
08:42 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
This is where LV's polymorph functions make things very simple: just wire the strings into an Equal? function (from the comparison palette), if they are equal the output will be a boolean true.
Mads Toppe
Check out our Modbus Test Master - developed in LabVIEW
1
Kudo
Message
2
of 2
(3,353 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
