Compare VIs without Professional edition
Is there a way to compare two VIs without the Pro edition? We have Full + Application Builder, so we don't have Copmpare VIs. I want to find minor differences in two huge VIs, and the thought of doing it "manually" is giving me the creeps. Ideas? Thanks!
This is on LV 8.2, not 7.1 as my sig suggests.
Message Edited by Broken Arrow on 03-13-2007 11:15 AM
Richard
(2,880 Views)
Richard:
The Compare tool available in the LabVIEW PDS version provides great information about the VIs. Since you do not have it, I would suggest you to look at the VI Hierarchy to find out some of the differences (although it may be huge if you have a big application with lots of subVI). You could use property nodes in LabVIEW to get the list of the VIs used. Short of that, I am not quite sure about what else to recommend you. Please let me know if you come across anything that allows you to do this.
Rudi N.
(2,859 Views)
