Compare Vi's doesn't work
I am using LabVIEW Professional Development System 2010 to compare 2 Vi's:
- opened up 2 VIs and do Tool -> Compare -> Compare VIs and selected the 2 VIs
- then selected the attributes I want to compare
- clicked "Compare"
After this nothing happens.
Can anyone please help?
Thanks..
(3,368 Views)
Hi Splee,
             First open the two VIs you wish to compare.
             Then,as you have already done Tools>>compare>>compare VIs
             Then a 'VIs to compare window will appears and there will be two select buttons.From them select properly the name of two VIs that you have opened now.
             Then click OK and then COMPARE.
             Nothing will happen if you have not entered a valid choice.Make sure that you have entered valid one.
This is actually not a serious issue.And you can be easily resolved by doing so.
           GOOD LUCK!
Thanks as kudos only:)
(3,352 Views)
I tried.
It does not work on my VIs, which are > 200KB in size.
It works though for smaller VI file.
Does the size of the VI file matter?
(3,315 Views)
Edit: After Posting I tried 600KB file it worked. Are you loading any vi which is running?
(3,312 Views)
still not resolved. After clicking the compare button,nothing happens..
(3,277 Views)
Works with LV2011 thought.
LV2010 - does not work
(3,259 Views)
