Compare analog signal with threshold in real time
Can you please check what I did? for the counter, I find problem. And for the voltage I'm not sure if it's correct. Thank you
Message 11 of 22
(1,505 Views)
That one's saved in 2018 again (sorry!)
GCentral
Message 12 of 22
(1,502 Views)
Sorry! This is the file on 2015 version
Message 13 of 22
(1,498 Views)
So I guess now you're happy with the voltages and locations, but for the count you need to connect it to the new count each time (not an array of coerced/converted times). So just connect the "# Found" to the Add instead of the I32 from the Times, and you'll be set.
With that minor modification, it should do what you want 🙂
GCentral
Message 14 of 22
(1,491 Views)
Ok, I will see. I have quesion: Now the location and voltage are for the values greater than thershold because for the voltage and location, it seems for me that they are no relation with comparaison, juste to more understand.
And my quesion is if I would do the same thin for values lower than thershold, I do the same thing for location and voltage. End for values equal to threshold. Thank you
Message 15 of 22
(1,488 Views)
Can you see the file, I would see what the programm gives as results, I stock them in TDMS file. So, I discover that the location, voltage don't have any relation with comparator. You can see the programm to understand what I mean.
Message 16 of 22
(1,482 Views)
I would that the programm detect the location and voltage where the voltage is greeater than threshold, and these values I think depend on sample frequency. And at the end, count how many time the values were greater than threshold. Thank you for your help
Message 17 of 22
(1,480 Views)
Yes - that's true. The evaluation is being done by the Peak Detector, because that seemed to be working for your application. If you need to split the array of data into multiple different criteria, for example, <0.5, between 0.5 and 1, more than 1, etc, then a different method should be used.
Here's a possible modification:
Note that part of the output to TDMS is broken in this modification because I'm using a 1D array of doubles, which don't directly contain time information (I'm not sure what the "dates" value was really anyway?)
You could make the same modification you already made with the shift registers to log them over multiple iterations.
Edit: To get the counts in this case, take the Array Size of the "Above", "Below" and "Between" arrays as needed.
GCentral
Message 18 of 22
(1,478 Views)
I think the peak detector is not necessary for my programm, I will remove it. So, How Can I do? Have you an idea?
Message 19 of 22
(1,477 Views)
Thank you so much
I will see your programm
Message 20 of 22
(1,475 Views)
