Compare array
Good morning everyone, here's my problem: I have an .ini file from which I need to extract values (there are several lines, with two columns: the first column shows the lambda value (nm) and the second column shows the corresponding values). Based on the current lambda value, I need to be able to select the correct other value and then save it to the file. I am currently using the “Read from text file” VI to select the rows, so I end up with an array containing all the rows I need. How can I tell LabVIEW that if, for example, the current lambda is 202 nm, it should only take the value of the array corresponding to 202 nm? I have no problem opening the file and “unpacking” the array, but I don't understand how to compare the values. I hope you can help me. Thank you.
(2,156 Views)
Hi giuli,
You can explore comparison pallet and use either "equals to" or "in-range and coerce" function.
(2,127 Views)
Words cannot really describe well what you actually want to do. But you seem to implement a simple lookup table.
  • Please attach a typical ini file.
  • Are the value integer or floating point? (com[paring floating point values is dangerous!)
  • So you want to save only one value to the file? What is the format?
  • Are the lines sorted by lambda?
  • What should happen if an exact lambda does not exist (find nearest? Interpolate? etc.)
  • etc.
If you have no problem "unpacking" (sic), why not attach your VI so we can get a better picture? It seems you are not really doing a "compare array", but searching one column. Not quite the same.
(2,120 Views)
Thanks for your reply! In the .ini file (I'm attaching an example), there are several lambda values (integers), and each one corresponds to a sensitivity value (E-14 format). The current lambdas in the program are in integer format, so they necessarily have a match in the file. I need the program to acquire the values from the .ini file and compare them with the current lambda. After finding the match, I need to save the exact sensitivity value. I hope I have explained myself clearly. I am attaching an example of VI (I am testing it before inserting it into the final program). As you can see, there is a while loop, so it does not exit until the exit condition (i.e., it has found the match) is met. Please forgive me, but I am still a beginner.
(2,086 Views)
Accepted by topic author giuli_
See if this can give you some ideas.
(Please don't use a greedy loop that continuously reads the same file over and over again as fast as the computer allows.)
(2,077 Views)
Thanks so much, I think it'll work. (The while loop was just a test, obviously.) The important thing is that for each value of lambda, it can calculate the value, and that's perfect. Have a good day.
(2,036 Views)
Of course you should also implement some error handing, for example you could return NaN if the entered lambda does not exist. Currently it would return zero.
(2,003 Views)
