Compare element in two 1D arrays and store in another 1D array
RightClick on Tunnel Mode and Select Concatenating.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 11 of 13
(1,075 Views)
You are connecting an array of booleans to the conditional tunnel which is probably why it's broken. You will need to make sure every element in that array is true to make sure you want to pass the array.
Message 12 of 13
(1,067 Views)
As a recommendation, instead of passing the array out of the loop, you can wire the integer value from before the while loop to the output tunnel to you won't have to reconstruct the integers afterwords.
Message 13 of 13
(1,065 Views)
