Compare real-time graphic to a database
Hello, I`m from Brazil and I apologize for any English mistakes I make.
I want to detect problems in a motor by analyzing vibration. I bought an accelerometer (adxl345) and an Arduino board to acquire the signals. The components haven`t arrived yet, but I want to start creating the LabVIEW application.
There are plenty of tutorials on how to analyze vibration on the internet and there are a lot of people who has done this before, but I can`t find anyone who has tried to compare a frequency domain real-time signal captured from the Accelerometer with a signal stored on a text or spreadsheet file.
What I want is to make an application that can automatically detects what is the problem on the motor, instead of comparing the graphics by myself.
Does anyone know if that is actually possible with LabVIEW? Maybe you can share some tutorial or knowledge on this.
I really appreciate any kind of help you can give. Thanks in advance.
(3,046 Views)
Hi otaconlink,
Look at these links about Sound and Vibration Measurements:
https://www.ni.com/en/support/documentation/supplemental/08/sound-and-vibration-software-overview-an...
Keep in mind much of this work can be done without the toolkits if you don't have them, but the white papers will start steering you into the right direction.
-SS
(3,041 Views)
Thanks for the links, I`m using the LabVIEW 2010 and I do have the Toolkits.
I`ll start reading those links.
If I find something that solves my issue I`ll mark your aswer as the solution.
(3,039 Views)
I coundn`t find a way to compare a graph to a database in order to have a match. Does anyone know how to do that?
(3,029 Views)
Olá,
Gostaria de avisa que agora temos o fórum em português. Você pode acessá-lo pelo link abaixo.
https://forums.ni.com/ni/?category.id=9170
Ou modificar o idioma no canto direito superior da página do fórum, como mostra a figura anexada.
Cordialmente,
Plínio Costa
Application Engineering
National Instruments Brazil
Plínio Costa
Senior Techinical Support Engineer
(3,008 Views)
Thank you for the tip!
(2,983 Views)
