Compare text in columns
Hi pickslide5,
to use the same StringX array as now you can use the "Format Into String" function before compare the strings. Therefore you could create a new array with strings like this:
%s, %s., -%s, (%s), ... and create the new string inside the for loop.
Mike
Message 11 of 13
(474 Views)
You don't really need to get that complicated. Use the regex code of "\b" to match a word boundary. Example:
In the above example if you set offset to 0 then "foot" is found at index=8. If you set offset to, say, 9, to search after the word "foot", then no match is found. I.e., there is no match against "footwell" or "footsy".
Message Edited by smercurio_fc on 03-17-2008 10:09 AM
Message 12 of 13
(463 Views)
This looks great - I have just now managed to get the thing to work with a massive great big array of every conceivable combination of: -foot foot, (foot- etc...
It took about 20 minutes to run through with my largest dataset!
I'll give this version a try - it looks a lot neater!
Many thanks!
Message 13 of 13
(452 Views)
