Compare two 1D Arrays minimal/max distance value
Accepted by JÞB
@medum wrote:
First if I have an an array with constant step size.
The other has differenz step size changing + 10, 11+ 10 and so an
For example:
x = 1,11,21,31,41,51,61,71,81,91,101
y = 1,11,22, 32, 43, 53, 64, 74, …
You show two arrays (x, and y) and they have different increments in value. The step size (one step per array index) is identical for both. You have an under-determined system.
Obviously the arrays differ and it is not obvious at all what you consider a "comparison" here. What determines the first derivative of the data? Could it be these should not even be integers and rounding to nearest integer causes the jitter?
Message 11 of 24
(768 Views)
yes i want to classify the jitte this should be equal?
I how can near that or calculate the jitter. My aim is more tje jitter
Message 12 of 24
(757 Views)
Upscaling didn't work like i thought it would. Using Initialize array you can '"upsample".
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 24
(753 Views)
coud i calculate the jitter between the both arrqys?
Message 14 of 24
(750 Views)
Why not do a linear fit of both and compare offset and slope?
Message 15 of 24
(744 Views)
I want an solution that shows the generellay equality of the both with  ranges.
I dont know of lineare fit helps?
Message 16 of 24
(740 Views)
For example:
It sounds like rho might be handy 😉
I know you prefer I/Q but Polar coordinates are useful too
Message 17 of 24
(738 Views)
  • Obviously, they are not equal. The best you can do is rate "similarity" by defining the term as used in this specific problem.
  • I have no idea what you mean here by "ranges".
  • If you don't know if something helps, just try it and see!
Message 18 of 24
(715 Views)
I want to calcultate the jitter from both?
Message 19 of 24
(711 Views)
sounds like a plan. Just do it!
(... after fully understanding the data and defining the type of jitter (periodic, random) and units you want (TIE, JCC, MD, MAD, RMS, etc.))
Message 20 of 24
(705 Views)
