Compare waveforms using CrossCorrelation.vi
I intend to compare 2 clock frequencies which deliberately vary in frequency value, to ensure they are not correlated, i.e. unable to trigger a scope off one clock to view the other clock.
I think that the CrossCorrelation.vi would be useful for this purpose. Having tried a few tests with simple sine wave inputs, I'm unsure of how to interpret the results.
I thought by using identical and dis-similar inputs that a I would be able to derive a test, but am unable to explain the vi output.
Does anyone have any experience using cross correlation and where I might get basic explanations on how to interpret the results.
Gary.
(6,872 Views)
Hi Gary,
Below is a link to an example VI that uses CrossCorrelation.vi to find the time delay between two identical signals.
https://decibel.ni.com/content/docs/DOC-12657
Both signals are input to the CrossCorrelation.vi. This then outputs an array containing the cross correlation data. Any large peak in this data will indicate a sample delay.
If you need some help understanding your own code, feel free to post it up here.
Kind regards,
Josh E
National Instruments UK & Ireland
(6,834 Views)
Gary,
Perhaps it would be easier to use a Fourier transform or Extract Single Tone Information.vi to check the frequencies.
Lynn
(6,826 Views)
