Comparing dynamic data with a constant
I have a dynamic data which includes time and amplitude information. I need to compare the amplitude which is in that dynamic data with a constant. Every dt I have a different signal component with distinct amplitudes, and I want to compare the amplitude of every signal component with a known constant. The oroblem is, the program did not allow me to compare with dynamic data which is "2d double" and a constant which is just "constant".
I would be very happy, if you help me on that.
(3,610 Views)
Accepted by topic author guldogusm
Hi guldogusm,
easy solution: don't use DDT for comparison!
There's a function named "From DDT" that might be a great help here…
(3,603 Views)
