Comparison of pixel values
I want to compare in terms of pixel value. If I explain simply , we're taking image from camera and saving that image.Then we are trying to find pixel values ​​in specific coordinates using both imaq get color pixel value and imaq integer to color value. It runs if we use only 1 image but if we use two images the screens mix and the pixel values ​​cannot be found. I would appreciate if anyone can solve this problem and move my project forward
Kind regards
(1,776 Views)
It's not clear what you are doing here.
Where are the two snippets in your main code?
(1,686 Views)
In your second snippet you are trying to create two RGB image buffers with the same name. The names must be unique for each buffer.
(1,679 Views)
