Compass
Hey, i'm kind of new to labview.
I have a project in which i need to measure wind's direction. I want to create a compass( since it looks better on the front pannel) but i'm having a problem with few things:
1- how to remove the space in a gauge indicator between the smallest number and the highest?
2- can i load a picture of a compass' rose to the program so that it will be the gauge's indicator?
any help is much appreciated
thank you in advance 🙂
(4,549 Views)
This question has been asked many times, and there are several good responses on these boards. Type 'compass' into the search box and you'll see these threads.
Keep in mind, the LabVIEW community is rich with content with over ten years of threads, so searching for what you need will actually help you arrive to your solution even quicker than asking! Smiley Happy I hope the following threads help you with your problem. Post back with any specific problems you are running into.
http://forums.ni.com/t5/LabVIEW/aircraft-heading/m-p/822676#M374018
http://forums.ni.com/t5/LabVIEW/Does-anyone-have-an-indicator-that-works-like-a-compass/m-p/156307
http://forums.ni.com/t5/LabVIEW/Compass-rose-or-gauge-and-3d-plot/m-p/912630
http://forums.ni.com/t5/LabVIEW/Genuine-compass-indicator/m-p/983423
(4,540 Views)
