Compatibility error with Community and Enterprise version
I was using the Labview community version for a long time and the program I had it was running fine on it. I'm using the DAQmx device and all its drivers are up to date. Recently, I bought the Labview 2021 sp1 version and now my program is showing that it is "ROOT CAUSE: Dependency is broken". I'm comparatively new to this environment. Is there any specific driver or add ons I need to install? Interestingly, both the community and the one I bought are of the same version (2021 sp1).
(1,315 Views)
Every time you install a new version of LabVIEW, you have to reinstall all the drivers and toolkits to make them "aware" of a new LV version.  Well, at least the drivers.  Not sure about the toolkits.
Bill
CLD
(Mid-Level minion.)
(1,278 Views)
