Compatibility of K Thermocouple with NI USB 6008
I have troubles choosing what to buy in order to make temperature measurements with my already bought NI USB 6008.
I plan to use LabView to work with these temperature measurements and link them to other measurements made with other sensors using the same NI USB 6008.
After few researches, I think i'll need a K Thermocouple like this one : http://fr.rs-online.com/web/p/sondes-de-temperature/3428899/
But my question is : will I be able to use it by just cutting the connector and linking the cables to my NI USB 6008, or do I have to use a special system like this one : https://www.ni.com/en-us/shop/model/usb-tc01.html
And if I need this kind of system, will I be able to use the measurements made with other sensors on the same LabView ?
My hesitations come from this document : https://www.ni.com/docs/en-US/bundle/usb-6008-6009-feature/page/introduction.html
Page 13, it seems i'll have to use 2 resistors to link my K Thermocouple to my NI USB 6008, but the use of such a system will make the certification hard to obtain (this system will make part a machine).
Hoping that you'll help me,
Patatelover, Polytech' Clermont-Ferrand, FRANCE
PS : Sorry for my english, I'm not native...
(6,060 Views)
Accepted by topic author Patatelover
The 6008 is not suitable for thermocouple measurements - see this article for details, but in short, you'd only be able to measure to a minimum resolution of 8-9 degrees with an accuracy of 30 degrees.
You should either use a USB thermocouple module like the USB-TC01 linked, a higher performance DAQ (with a smaller range / higher resolution) or use a Thermocouple C-Series module.
(blog)
(6,045 Views)
Thanks a lot for this quick answer !
(6,036 Views)
Another little question,
- Is it possible to use the USB-TC01 (for thermocouple) and the NI-USB-6008 (for other measurements) SIMULTANEOUSLY and acquire both measurements on the same Labview  ?
- If not, could you advise me a higher performance DAQ that would be able to work with thermocouple (directly linked with the sensor) and other sensors like force sensor ?
(6,017 Views)
1) Yes, you can create two tasks (one for the thermocouple measurement, one for your other measurements) in the same VI.
2) Something like this would give you 4-channels of measurements, or you could look at the M-series or X-series devices.
(blog)
(6,006 Views)
