Compatibility
 Is it possible to use MyRIO 1900 along with Xilinx software instead of LabVIEW??
(3,204 Views)
Accepted by topic author ChaitraBhat
Hi Chaitra,
LabVIEW is already using Xilinx compilers under the hood!
So what exactly do you want to change?
(3,141 Views)
Thank you for your answer!
I actually want to interface pmod tmp3 sensor and monitor the temperature on Myrio FPGA using microblaze softcore processor.
I initially created a simple microblaze block diagram on vivado, generated the vhd files, imported in labview using CLIP.
My doubt is that
1) Board support files for MyRIO FPGA board is not available in vivado. I am using vivado 2016.4, LabVIEW 2015 What should I use instead ? Which board should be used? All the available board files are for digilent boards.
2) Should I include Pmod libraries in vivado to interface Pmod tmp3 ? and then import it into LabVIEW ? But how would I get to know which pins of myrio are exactly resembling the one in the microblaze block diagram.
(3,061 Views)
Thank you I got it !
(3,016 Views)
