Compatible Sound & Vibration Toolkit for LabVIEW 6.1
In the Ordering Information of the NI LabVIEW Sound and Vibration Analysis Toolkit(file attached) following is mentioned :
NI LabVIEW Sound and Vibration Toolkit*...........777970-03
Run-Time License ............778042-01
*Requires LabVIEW Professional or Full Development System 7.0 or later.
Which version of NI Sound & Vibration Toolkit is compatible with LabVIEW Professional Development System, Version 6.1 ?
(3,438 Views)
The version of SVT that supports LabVIEW 6.1 is ver 3.1. There has been several major performance improvements in the new SVT 4.0, including new Express VIs that makes the use of SVT a lot easier. It's recommended that you update your LabVIEW to the current 7.1 version so you install the latest version of SVT.
If you can only use LabVIEW6.1 with SVT, you will have to give NI a call and see if we still offer an older version of this toolkit, most likely it is obsolete.
(3,419 Views)
