Compilation Errors with LabVIEW FPGA Module
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/cceae7847f41c36a86256d1f0070d224?OpenDocument
I get the same error as described in the knowledge base article linked above. However, the problem remains even after making the correct entries for the compile server configuration dialog box. I continue to get the same error.
I am using an evaluation version of LabVIEW 7.0 - could this be causing the problem? Or is it something that is not done right during installation?
Thanks in advance for any help.
(3,374 Views)
Could describe exactly which product you have installed and in what
order you installed them? Is there a reason you are using an
evaluation version of LabVIEW with the LV FPGA module. I don't know if
this combination has been tested or is even supposed to work.
Can you verify that the FPGA resource directory (default location -
C:\Program Files\National Instruments\LabVIEW 7.0\RVI\resource) is
present on your system.
Christian L
NI Consulting Services
(3,374 Views)
Christian,
It was a problem with the Evaluation version of LabVIEW 7.0. I was using it temporarily until I got the LabVIEW 7.0 CD from NI. With the development version everything works just fine.
Thanks.
(3,374 Views)
