Compilation error - FPGA NI PXI-7951R board - ERROR: Xst: 2472 - Top module <Puma15Top> was not found.
Hi Guilherme,
You have a log attached, the problem occurs after compiled our CLIP entities:
Compiling vhdl file "C:/NIFPGA/jobs/pC00o5g_uIgCQHB/CLUC001_Conf.vhd" in Library work.
Entity <CLUC001_Conf> compiled.
Entity <CLUC001_Conf> (Architecture <behavioral>) compiled.
Compiling vhdl file "C:/NIFPGA/jobs/pC00o5g_uIgCQHB/CLUC001_CLIP.vhd" in Library work.
Entity <CLUC001_CLIP> compiled.
Entity <CLUC001_CLIP> (Architecture <rtl>) compiled.
Entity <CLUC001_CLIP> (Architecture <behavioral>) compiled.
ERROR:Xst:2472 - Top module <Puma15Top> was not found.
ERROR:Xst:2469 - Please specify the correct library via the -work_lib switch.
thanks
Jean
Message 11 of 23
(1,727 Views)
Hi Guilherme,
Yes, it is.
Regards
Message 12 of 23
(1,721 Views)
Hi Pedro,
It was done, I sent him a log.
Thank you
Jean
Message 13 of 23
(1,721 Views)
Hello, Jemp,
Thanks for your answer. I need to know if you are using the  FlexRIO Adapter Module Development Kit?
Wich Operating System are you using?
Pedro Ivo da Cruz
Engenharia de Aplicações
Message 14 of 23
(1,685 Views)
Hi JEMP,
Onde more thing, Is the CLIP you are compiling one we provide, one they have created youself, or a CLIP that you got from a third party?
Pedro
Pedro Ivo da Cruz
Message 15 of 23
(1,682 Views)
Hi Pedro,
No, I not using FAM Development Kit.
In the development computer (where max is installed) is windowns and in the PXI is RT.
The CLIP socket was writen by myself.
Att,
Jean
Message 16 of 23
(1,679 Views)
Hello JEMP,
Have you gonne through the process described in this white paper? If so do you get any warnings or errors when going through the process?
Pedro Ivo da Cruz
Message 17 of 23
(1,661 Views)
Hi Jean,
Did you have any problem going through the White-Paper I posted in my previous post?
As I am working with the Engineers from United States on this problem, I need your answer as soon as possible.
Pedro Ivo da Cruz
Message 18 of 23
(1,641 Views)
Olá Pedro,
No I didn't have any problem through this procedure.
I used this procedure for CLIP, and the checks has no error neither sintax nor any other kind of error!
Best
Jean
Message 19 of 23
(1,635 Views)
Hi Jean,
I need some more details about your application.
What are you trying to accomplish with this CLIP?
What specification or functionality are you trying to access with this CLIP?
So I can check if it is entirely necessary.
Pedro Ivo da Cruz
Message 20 of 23
(1,616 Views)
