Compilation failed
Hi, I cannot compile because of the error in the photo attached. Does anyone know how can I solve this problem?
Thank you
(2,028 Views)
Are you able to connect to your compile farm?  Do you even have a compile farm to use?  Does it have a worker that can work with your version of LabVIEW?
(2,015 Views)
I have a compile worker running on my pc. The version of the worker is 2020. And the version of LabVIEW is 2017. Also, I started to use compile cloud in June and I have never encountered such compilation error.
(2,005 Views)
