Compile Error When Running FPGA VI
Primary Software: LabVIEW Modules>>LabVIEW FPGA Module
 Software Version: 8.6.1
I have an FPGA VI which uses 3 sin_generators. When I compile the VI, the compiler returns the error
Sine_geneartot_rvi_FPGA_main_vi_FPGA compile copy 1_vi_intance
Line_21 width mismatch. Expected width 8,actual width is 16 for dimension 1 of  lutoutERROR:Xflow – Program xst returned error code 6. Aborting flow execution.
Why does this occur? How can I prevent it?
(2,795 Views)
Could you please post your VI here?
Christian
(2,790 Views)
I  will  post  this   fpga VI  tomorrow.thank you
(2,782 Views)
