Compile window prevents code from deploying
Has anyone else seen this issue?  sbRIO RT code builds fine using LabVIEW 2015. When I select, Rujn as Startup it gets about half way complete then displays a compliling dialog box that just hangs.  My deploy dialog says sucessfully completed but can't click on close because the hung complie window.  In the end it doesn't finish deploying my code to the sbRIO.
I have worked around this before by using Mass Comile but not helping this time.  Any suggestions?
Matt
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
NI Certified LabVIEW Architect
LabVIEW, LV-RT, Vision, DAQ, Motion, and FPGA
(4,278 Views)
Which sbRIO board do you have?
What is your OS?
(4,245 Views)
Accepted by topic author CAS_MattF
Christian,
This is NI's new sbRIO 9607 that requires LabVIEW 2015.   I have created my "work around" for the issue using these steps.
  1. Mass Complile code
  2. Clean
  3. Build
  4. Deploy (puts it in memort)
  5. Set As Startup (saves to NVRAM and sets as start up)
I also checked the box that closes deploy dialog on sucessful compleation.  Took a while but this is what works for me.
Thanks!!
Matt
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
(4,154 Views)
