Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results forÂ
Search instead forÂ
Did you mean:Â
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
CompileFolderCore: error 8
Scipio
Member
‎07-24-2007
04:38 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I'm getting the error message "CompileFolderCore: error 8" for several libraries (llb files) when doing a mass compile. Can't find any clues in LV Help or in the Knowledge Base.
Any help will be appreciated. Thank you!
0
Kudos
Message
1
of 4
(4,287 Views)
Reply
Re: CompileFolderCore: error 8
Scipio
Member
Author
‎07-24-2007
05:58 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Found the error code description:
LabVIEW: File permission error. You do not have the correct permissions for the file.
The mass compile can't proceed on a read-only library.
1
Kudo
Message
2
of 4
(4,283 Views)
Reply
Nick R
NI Employee (retired)
‎07-25-2007
12:57 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi Homiachok,
Is your .llb file read only? The error is pretty specific that you cannot mass compile a read-only library.
Nick R
NI
1
Kudo
Message
3
of 4
(4,272 Views)
Reply
Scipio
Member
Author
‎07-25-2007
01:19 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Yes, Nick, that's what the problem was. Once I've made the library writable the message went away. So this was an easy one! :^)
Thank you!
0
Kudos
Message
4
of 4
(4,267 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
