Compiled Code Error Running Excel
Writing to Excel works fine with source code but gives this error with compiled code:
Open VI Reference in Dispose Report.vi->Write_to_Excel.vi->Golden_Thread_V2.vi<APPEND>
VI Path: <b>C:\Golden Thread\Golden Thread V2.2.exe\Excel_Quit.vi</b>
Built Application or Shared Library (DLL): Make sure all dynamically loaded VIs were properly included in the build specification for the application or shared library.
Any thoughts???
Thanks.
(3,520 Views)
Hi SJT,
if you use the report generation toolkit, it could be that there are some dynamically loaded vi´s, so make sure that all these vi´s are in your executable and that the paths are correct.
Mike
(3,508 Views)
Mike,
Thanks for the reply.  I have a few follow-ups, though:
1. How do I determine if a VI is flagged as dynamically loaded.  I'm sure I didn't select it.
2. How do I make sure they're in the executable.  I'm using LV8.5 and I have a project created.  Do I add the VI as a file to the project?
Thanks for your help..
Steve
(3,496 Views)
Hi Steve,
if you use for example the "Append Table to Report.vi", then you have in the "Excel" case a dynamic loaded vi, also in the "New Report.vi". See the picture.
See this KB: http://digital.ni.com/public.nsf/allkb/C38CE3F30542D65B86256F0E00740DD8
Mike
Message Edited by MikeS81 on 06-18-2008 03:42 PM
(3,492 Views)
Mike,
That worked!  Thanks for the help.
Steve
(3,473 Views)
