Compiled exe with labview crash at launch
Hello all,
I have an i7 with windows 7 64 and Labview 2012 SP1 installed on it. I did not have any problems with it since now. I'm facing with a strange issue regarding any VI compiled with labview, also a simple Message Box stating "Hello world". If I launch the VI from labview, everything is fine, but if I create an executable it crash at launch without returning any error. Exe is working well on another PC with LV runtime, so the issue is regarding my PC only.
I have tried to reinstall labview runtime without success. I have also tried to compile a debug version of the exe, but debug server do not find it.
If I debug it with MS VC++ the only thing I see is the following exception:
First-chance exception at 0x7789c41f in Application.exe: Microsoft C++ exception: LVExcept at memory location 0x0018e484..
First-chance exception at 0x7789c41f in Application.exe: Microsoft C++ exception: [rethrow] at memory location 0x00000000..
The thread 'Win32 Thread' (0x1194) has exited with code 0 (0x0).
The thread 'Win32 Thread' (0x324) has exited with code 1 (0x1).
Hope that some of you could help without reinstalling the entire operating system!
ciao
Daniele
(3,621 Views)
Do you run any kind of PC security software? Which one? (e.g. avast seems to be causing problems once in a while)
also:
Have you tried to repair the LabVIEW installation?
Did you also install any run time engine, and if so, which one?
(3,603 Views)
Thanks for you answer.
I have OfficeScan antivirus running, but it is running also on other colleagues laptop that have no issues.
I have LV 2011 runtime installed since awhile.
Reinstalling the LV2012 developing environment would be my last chance.
(3,594 Views)
There have been numerous report with trend micro (here, here, etc.). Can you temporanily turn it off and see if the problem presists?
(3,591 Views)
OfficeScan unloaded, but problem is still there.
(3,572 Views)
