Compiler Error. Report this problem..... bad doffset, dso= -1
I'm running several script nodes from Matlab. They all take inputs from various other components as well as other script nodes. I get this error when I attempt to add an output to a node that resides inside a case structure. It occurs when I save the VI for the first time after the change.
Anyone else get this? Can I put a delay in to fix it?
Adam
(2,696 Views)
Ha I fixed it. If you happen to save your work while you have an output from the script node that isn't connected to anything, this error occurs. As I frequently save my work every minute or so, this is often the case. Creating a stub output indicator and attaching it readily solves the problem
(2,686 Views)
