Compiler Error With an Overridden Method.
Hi all,
I got 5 compiler errors that traces back to an overridden method. That also gets a broken arrow with a generic error message. Pressing the broken arrow will recompile the VI and it then works??
Any suggestions on how to get rid of these would be appreciated (they pop up in sequence after clearing the compiled object cache):
Br,
/Roger
(4,904 Views)
Not a single reply from a member, champion, knight, NI AE or even from a expired SR issue ticket.
Challenge Accepted!
What else than to jump into the LV wizard coder dungaree outfit and boot the LV compiler to the bitter taste of hours old tannin laden coffee.
Okay, enough of that nonsense: Here is the recepie to get rid of the compiler errors.
Anyone out there experiencing the same compiler bugs could try it out and see if it works?
1. Create an inlined sub vi containing the code causing a broken arrow and compiler errors.
2. Move out the "Call parent method" VI from the inlined VI.
3. Mission accomplished! No more compiler errors. Yet another successful LV workaround hackery.
Br,
/Roger
(4,888 Views)
Hi Roger,
Thanks for bringing this to our attention! I'd like to file a Corrective Action Request to our R&D department so that they know about this behavior. Would you be able to attach your original and workaround code to this forum so that I can show it to them?
Thanks!
Alexandra Valiton
(4,807 Views)
Hi Alexandra,
I have already sent the source code regarding the service request in the post above. Check on the NI FTP or perhaps Klas Andersson can help you?
Br,
/Roger
(4,795 Views)
Hey Roger,
Our FTP site gets wiped regularly due to high volume, so your code is no longer there. Please resubmit your code there and let me know the name, or attach the code here.
Alexandra
(4,787 Views)
@Alex+ra wrote:
Hey Roger,
Alexandra
Git is fantastic. Uploading now. Smiley Very Happy
ftp.ni.com:21/incoming/7342472_Compiler_Error.zip
It should be there in 15 minutes.
Open the LV2011 project: rioPilot/rioTarget.lvproj
Br,
/Roger
(4,785 Views)
Hi Roger,
I wanted to let you know that I've filed a Corrective Action Request (CAR) for this issue. It is CAR #377589. In new releases of LabVIEW, you can check the documentation for fixed issues, and you'll know the issue has been addressed if that CAR # is listed there. Thanks for helping us make LabVIEW better!
Alexandra
(4,773 Views)
