Compiler error.
Hi
I have a strange problem with one VI, when i turn on parallelism on for loop, im getting compiler error. Could any of you check this vi?
BR
http://www.krzysztofszewczyk.net
(2,860 Views)
Hi Krzysztof,
the error seems to be related to the FOR loop output tunnel: when you change the tunnel behaviour you can set parallelism of the FOR loop.
In the background a shift register is used to index the output array - and shift registers aren't allowed for parallelism in FOR loops.
The LabVIEW compiler gurus may provide more detailed information and insights...
(2,853 Views)
