Compiler is Too Smart for My Own Good
Here the "FP.Close" runs before the case structure!  The darned compiler knows that the reference will be unchanged, so it doesn't wait for the case.
Message 1 of 55
(4,704 Views)
So you're trying to be cute (but also correct) by wiring the reference through the case structure to create an "artificial" dataflow dependency, and the compiler outsmarts you by compiling as if you had the reference wire outside the case structure.  So how did you fix it?  Error cluster inside the case structure going to error in on front panel close?
This is alarming to me.
Bill
CLD
(Mid-Level minion.)
Message 2 of 55
(4,699 Views)
Well, I believe NI says not to wire through a structure unless something somewhere in the structure needs the data, so I guess there's that...
Bill
CLD
(Mid-Level minion.)
Message 3 of 55
(4,687 Views)
Synchronize Data Flow.vim could be used (one input being the panel reference, another being the error).
Message 4 of 55
(4,672 Views)
Nice.  I suffer from being too lazy to learn all the new stuff from version to version.  In fact, it's posts like yours that cause me to add another tool to my tool bag.
Bill
CLD
(Mid-Level minion.)
Message 5 of 55
(4,661 Views)
Here's how I fixed it:
Message 6 of 55
(4,658 Views)
Looks like "Rube-ish" (pun intended) at first glance, but when you know the reasoning behind it...
Bill
CLD
(Mid-Level minion.)
Message 7 of 55
(4,649 Views)
I, for one, am very interested to see how you figured this one out!
Message 8 of 55
(4,625 Views)
I guess this is Stupid Question Time (for me at least)...why aren't you wiring that error wire to the FP.Close Invoke Node?
Message 9 of 55
(4,620 Views)
Fortunately Highlight Execution worked in finding it.
Message 10 of 55
(4,606 Views)
