Compiler not detecting 'known pattern'
Hi, I would appreciate some help on the following: why does the attached diagram result in a buffer allocation?  The known pattern of unbundle-operation-bundle' is detected properly, but the 'index-operation-replace subset' results in a buffer allocation.  Both of these should be known to the compiler and not result in a buffer allocation.   The structure is:  cluster of arrays of clusters (the cluster in the array only consists of scalars).
Any clues will be appreciated.
Thanks.
(2,657 Views)
You should not start different threads all over the place. It is best to keep the discussion to a single place, even if the original title is not fully descriptive.
___________________
Try to take over the world!
(2,655 Views)
In my mind this was a different issue though, but I take your point.
(2,651 Views)
