Showing results forĀ
Search instead forĀ
Did you mean:Ā
Compiling Error for Sbrio 9607
Hi all, I built a program for the sbRIO-9606 and 9683 (RMC) at 80 MHz, and it compiled without any errors. However, when I try to compile the same program for the sbRIO-9607 and 9683 (RMC) at 80 MHz, I’m facing a timing error.
(900 Views)
My question is: What happens when you "Click the Investigate Timing Violation button to display the Timing Violation Analysis window." as stated in the Reports Summary?
(883 Views)
This is the my Timing Violation Analysis window
(830 Views)
