Compiling IVI-C driver source code
I'd like to make some fixes into source code of IVI-C driver 'cause I have found some SCPI-command bugs in there.
What are main steps in compiling the source code, which library function I must include (VISA-library?)?.
I'm using LabView 7.1 and the driver in question is agpsgmxg (source code file is agpsgmxg.c) which I have downloaded from NI's idnet.
I have MS Visual Studio environment.
(3,334 Views)
Wrong board. You want to post to the LabWindows/CVI board. That is what is used to create all IVI drivers.
(3,328 Views)
In CVI you would use Ctrl+K for compiling and then you would re-create the DLL and replace or rename it the existing one that is in IVI/Bin or IVIFoundation/Bin. Can you send feeback to instrument.drivers@ni.com mentioned with the bugs found in the driver?  So we can document and look into the issue?
(3,307 Views)
Thanks for your answers. I'll send feedback about that driver to NI.
(3,286 Views)
