Compiling code for LPC2378 Target using LV Embedded
Hi
I am using LabVIEW embedded for ARM 10 and using MCB2370 evaluation board. I did my evaluation successfully but now when I tried to compile the same code for an lpc2378 target (tier 2), I am getting "Error: Application is too large for target memory. Status: Build failed."
I am only doing serial communication using com 0 and using no other peripherals that are custumized for MCB2300 target.
what should I do to resolve this issue?
thanks and regards!
Mani
Message 1 of 1
(2,802 Views)
