Compiling or Synthesizing HDL code partially
I have a VHDL code which I am integrating in my VI using IP integration node. I want to see that when I will be compiling my overall VI, whether LabVIEW Xilinx compiler will accept this code or not. So, is there any option through which I may compile my HDL code first/quickly  just see whether ultimately that will be accepted or not.
Background: Actually every compilation of the complete module takes almost 45 minute, just to tell me that there is some issue in my HDL code. So, just to save time, I need to compile my design faster/ or at least my HDL code, just to see whether it will pass or fail eventually.
Thanks for help
Cheers
TahiR
(2,798 Views)
Hello!
To compile your design faster have you tried this LABView FPGA compile cloud service? https://www.ni.com/en/support/documentation/supplemental/14/compile-faster-with-the-labview-fpga-com...
I hope it helps!
(2,758 Views)
