Completely Uninstall Labview and NI Software
An installer generated by the app builder in LabVIEW. I have used this same installer successfully on many other systems, but for some reason it's just not playing nicely with this one computer.
Message 11 of 21
(3,381 Views)
Bumping for help. Does anyone know how to get NIUninstaller or this Blast program that has been mentioned?
Message 12 of 21
(3,349 Views)
Bumping again for help. Does anyone know how to get NIUninstaller or this Blast program that has been mentioned?
Message 13 of 21
(3,330 Views)
1. Programs and features ->  [your program]
2. Programs and features -> National Instruments Software -> "Remove all".
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 14 of 21
(3,216 Views)
But that will not work through SCCM
To uninstall Labview completely, and completely Unattended, you need to do the following:
"C:\Program Files (x86)\National Instruments\Shared\NIUninstaller\uninst.exe" /qb /ForceDependents /x "NI LabVIEW 2018 SP1 (64-bit)"
To uninstall fx Multisim:
"C:\Program Files (x86)\National Instruments\Shared\NIUninstaller\uninst.exe" /qb /ForceDependents /x "NI Circuit Design Suite 14.1 Education"
(the exact name to use for the uninstall can be found in the c:\Programdata\National Instruments\install.log...)
To install ALL use:
"C:\Program Files (x86)\National Instruments\Shared\NIUninstaller\uninst.exe" /qb /x all
Message 15 of 21
(3,199 Views)
What is "SCCM"?
Message 16 of 21
(3,194 Views)
System Center Configuration Manager.
Used for unattended installations for when we need to roll Labview out to appr 1000 PC's..
Message 17 of 21
(3,190 Views)
To install ALL use:
Message 18 of 21
(3,186 Views)
Why did you repeat your earlier message?
Why can't it work on that SCCM?
It seems that if you have have a short list of uninstall commands, you should be able to script them in your system manager.
Message 19 of 21
(3,183 Views)
I just answerede chenm0416's original question..
Message 20 of 21
(3,179 Views)
