Complex addition
Hi there,
I was wondering how I could do a complex addition. Right now, I have 2 vectors X and Y of the same length. I wanted to do X + iY and then graph the results. How would I go about doing this in LabVIEW? Thanks.
-Mike
(2,932 Views)
Hi Mike,
I'm not sure if you need a complex addition. Thus, you can plot X+iY without involving complex related functions (using XY graph). Anyway, you can use these functions (in Numeric -> Complex palette) in order to obatin complex values (to do some other operations easier).
Take a look on attached example ... ignoring my loop used to generate the arrays.
Hope this helps.
(2,932 Views)
