Complex in Formula Node
I need to enter the following formula (j-imaginary 1) in Formula Node
x1=1/kr - j/(kr*kr) - 1/(kr*kr*kr);
x2=1/(kr*kr) - j/(kr*kr*kr);
Further I need to receive y = x1*conjugate(x1) + x2*conjugate(x2).
I do not know, how it is necessary to designate complex x1 and x2 in Formula Node and how to program conjugate. Help me, please!
(7,907 Views)
Accepted by RavensFan
Formula node do not support complex numbers. But a Mathscript node do. But I am not sure you find Mathscript node in LV 7.1. But I think you are making things to complex. You do not need a formula node
Edit: Upsk made an error in the calculation, but it is fixed now
Message Edited by t06afre on 03-07-2009 12:03 PM
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
sample.vi ‏1 KB
(7,884 Views)
Thank you!
(7,873 Views)
tumanovalex wrote:
Thank you!
This post is certainly NOT the solution and thus should not be marked as such. Please mark the post containing the actual answer instead. Thanks!
(7,863 Views)
Please don't mark this as solved
(4,781 Views)
You're right.  This is rather old (12 years) and the original poster marked his own thank you message as the solution which is improper.
I've remedied this.
(4,774 Views)
I think Re: Complex in Formula Node) is pretty good, and as good as it gets for sure...
(4,739 Views)
