Complied program can not find GPIB and serial devices
I wrote a program (Labview 2009) and it runs fine on my PC.
After I compile it and try to run it on another PC (Dell Laptop) it cannot find my GPIB nor my serial device.
I have Measurement&Automation installed on the laptop and the GPIB device shows up and communicates from there.
I also have my serial device (a relay board) working from the relay board’s software.
I know the hardware is working but Labview doesn’t see them.
I get the error code 1073807202 for both the GPIB and serial device.
Help, please!
Tony
(2,842 Views)
Accepted by topic author TonyReo
Did you install the VISA Run-Time engine on your computer ? Also are you using NI Serial and GPIB (488.2) based hardware ? If this is the case, you have to install the NI Serial driver and NI 488.2 driver.
https://www.ni.com/en/support/downloads/drivers/download.ni-serial.html
https://www.ni.com/en/support/downloads/drivers/download.ni-488-2.html
(2,837 Views)
Thanks for the quick response.
I assumed the VISA runtime was included in the Labview Runtime Engine.
Am I incorrect?
Tony
(2,826 Views)
Wrong ! This is not included in LabVIEW RTE 😉
(2,823 Views)
