Compliling VI in LabVIEW with cRIO-9004 controller and cRIO-9104 chasis
I have been trying to compile in LabVIEW with cRIO 9004 and cRIo 9104 connected.
It has three options
1) use local compile server.
2) connect to network compile server
3) connect to LabVIEW FPGA compile cloud service
But I am unable to compile my programme using any of these.
how can I get my compilation done?Please help.
Thank YouCp
(4,129 Views)
You need to be more specific. What kind of error messages are you getting?
(4,120 Views)
sir,
When I try to copile using local server it says that Xilink 10.1 not present.
When I try to so it using LabVIEW FPGA cloud compiler it says that your licence has expired whereas I have a licenced version of LabVIEW.
How can I over come this error?
Where will i get Xilinok 10.1?
Thank You
(4,113 Views)
srry its Xilinx 10.1
(4,103 Views)
You need to have a valid SSP for your license to use that compile farm.
If you have a valid SSP, you should also be able to download the Xilinx drivers from the wwebsite.
If not, the you should be able to find the Xilinx version that you need on the DVD's that you used to install you LabVIEW modules.
(4,086 Views)
what is SSP?
(4,074 Views)
Accepted by vinayak1011
SSP is the Standard Service Program, it is a yearly fee to NI, that in return let you upgrade your LabVIEW and modules and have support from NI.
https://www.ni.com/services/software_benefits.htm
(4,061 Views)
