Computer 5V or 0V output to Sensaphone Express II
I'm using a LabView controlled alarm system in my lab where an alarm condition triggers a USB DAQ analog output signal to switch from +5V to 0V. This signal is going to a sensaphone express II alarm box normally open relay input. The normally open relay input sees 5V as an open (no alarm condition) and 0V as a short (alarm). My problem is the my USB DAQ only has 5 analog output and I would like to have more. I don't want to spend a lot of money. Any suggestions on an inexpensive USB DAQ or PCI DAQ with similar functionality but more channels? Or better yet a way to get a similar effect straight out of the computer? Maybe USB? RS232?
(4,086 Views)
What DAQ card are you using? It doesn't have any digital outputs?
USB or RS232 won't do you any good. You could use the parallel port.
(4,084 Views)
I'm using an iotech personal daq 3000 series.  It does have digital outputs.  The problem with the digital outputs is when I set the output to 0V and expect to see a short between the digital output channel and ground I see something like 400 ohms.
(4,072 Views)
Set your meter to volts, not ohms. I bet they are TTL outputs, not contact closure outputs.I'm not about to register at MCC's site to download the data sheeeet.
-AK2DM
(4,062 Views)
Instead of driving the sensors with analog or digital signals, you could drive relays and have actual shorts and opens instead of some active circuit.
(4,060 Views)
I guess I could drive relays with the outputs.  I was hoping to end up with less hardware instead of more.  Something really simple.
(4,050 Views)
