Computer recomendations, Dell's For LV8 using 500Ks/S 6031E PCI card?
Ok So im going to buy a computer for recording data using LV8. What are the requirements for the computer?
FSB speed? is 533 enough? 800?
Ram? 256MB DDR2 SDRAM at 400MHz -1 DIMM
Processor? Intel® Pentium® 4 Processor 521 w/HT Technology (2.8GHz,800FSB)
Computer will be a Dell, and im sure more is better with everything. But what is the minimum i need as to not choke the capacity of that card.
Message 1 of 11
(3,572 Views)
Vr6...
I would presume that the 6031 card handles all it needs via onboard hardware WRT signal acquisition and timing. It is the post processing in software that will tax the PC hardware. If I am wrong here, someone please set the record straight.
I would bump up the RAM as suggested by NI in the LV 8 Upgrade notes to at least 512MB.
Personally suggest you go with 800MHz FSB
Video? At least 1024x768 capable per upgrade notes. If application is graphics intensive, I would suggest a dedicated AGP or PCI-e card over an on-board video adapter.
Hard drive- probably not an issue WRT speed or capacity. LV needs 1.2G for full install. SATA's are faster than IDE's
At least one open PCI slot if going with the PCI version of the 6031
That's all I can think of
Message 2 of 11
(3,547 Views)
Celeron or pentium?
Is my 6031E PCI-E or PCI-x compatible?
Message 3 of 11
(3,533 Views)
Here's a link to the manual for the 6031E and brethren:
It looks as if the 6031E only comes in standard PCI and PXI formats.
I would go the Pentium 4 route.
WARNING: Looking at your message title, you want to sample at 500ksamples/sec. I think the 6031 has an aggregate rate of only 100ksamples/sec. Please check the manual to verify. I have no experience with this card.
Message 4 of 11
(3,524 Views)
I wouldn't recomend a celeron for any kind of serious work.
The 6031E (and all E series boards) are PCI only. Some of the newer M series boards are available in PCI-Express versions. The M series boards have better specs and cheaper as well.
Message 5 of 11
(3,517 Views)
Yes i was just schooled by my local sales rep. Now i know a few things. Im gonna get an optiplex pentium.
Ram suggestions?
Message 6 of 11
(3,500 Views)
6.72 TeraQuads worthhappy smiley But that will cost you a lot of gold pressed latinum.
 Again, NI recommends at least 512M, and not knowing what you plan to run SW wise on the system, personally I would get at least 1Gig. Memory is 'cheap' these days.
Message 7 of 11
(3,492 Views)
I wouldn't recomend a Celeron to prop a door open.
I had problems getting LabView 7.1 to address more than 2G of ram on an XP machine.  I.e. on a 4GB machine, I would still get "out of memory" errors with "only" 2G in use.  I don't know if this is a limitation of LabView or Windows.  I have not pushed my luck with LV8 (yet).
Message 8 of 11
(3,487 Views)
Have my eye on this now:
OptiPlex GX520 Desktop: Intel Pentium 4 Processor 640 with HT (3.2GHz, 2M, 800MHz FSB) 80GB HD
Running XP pro
Message 9 of 11
(3,484 Views)
Very well, but avoid the desktop and small form factor case, you will have a hard time fitting a full height PCI card in only a low profile PCI slot of 2.5" high.
Again, to reiterate, the 6031E will not sample at 500ks/s no matter how poerful of a PC you have.
Message 10 of 11
(3,481 Views)
