Computer related problem
I have a general question about computers. I am using Labview to control how a reactor opens and closes valves to deposit gaseous materials on a surface. The labview program runs fine in the first few minutes (first 20) but as I repeat the number of deposition cycles, the whole program freezes and I always have to restart the computer. I think this is a computer related problem not Labview's fault. Any ideas on how I can fix that? Thanks a lot.
Sicelo
(3,218 Views)
Use the Windows Task manager to monitor the CPU and memory usage while you code runs.
What you should loof for is;
Is memory usage increasing?
Is CPU usage increasing?
After you know what is happening post your code and what you found to get more hints.
Ben
(3,217 Views)
After you do as Ben suggests.  look through your code for:
  • Resources initialized repeatedly (DAQ tasks should be created ONCE, instruments Initialized ONCE...)
  • References you opened and did not close (Some you don't need to worry about but some you do!)  Ben will probably post a link but a forum search would find a few points. (Check Ben's Tag cloudSmiley Wink)
  • data structures (Arrays or Strings) that keep growing and growing demanding larger and larger buffers eating up huge chunks in memory
(3,210 Views)
The program is currently running. I closed off everything else on the computer.
CPU usage:10-14%
Memory usage: 1.13 GB
Both of these are not increasing but I know that after 20 minutes the program freezes anf does not respond anymore.
Thanks.
-Sicelo
(3,204 Views)
CPU usage:10-14%
Thanks.
-Sicelo
Check it again after 19 minute 30 seconds.
Ben
(3,198 Views)
then its probably unnecessary re-creation of DAQ Tasks or re-itnitialization of instruments
(3,197 Views)
