Concatenate strings
What I'm trying to do is, read a few rows from a file, concatenate a constant to each row and save the final result
From file a.txt:
n4
n3
n2 etc
Final result:
$n4
$n3
$n2 etc
What I did, I get the number of rows
The loop would loop by the number of rows.
I then concatenate '$n' with the number, which I change, number to string
Is there any other way to get the same result without ignoring the data in the file? I do realize that I'm not at all using the data from the file apart from to know how many row is it, and recreate new data (by adding '$n' instead of just '$'), and by chance that the input (a.txt) is in the right order, ie from 0-any number. But if I'm using numbers that don't relate to each other (10, 6, 1, 7...) I can't concatenate it the way I did here as it won't give the right output
Thanks 🙂
(4,298 Views)
Accepted by topic author a01lida
Hi a01lida,
  Ofcourse you cant ignore the data as you are reading the file.You can use read text file function and select option as "read lines" and use.Pleas go through the attachments.
Thanks and regards,
srikrishnaNF
Message Edited by srikrishnaNF on 12-02-2009 10:10 PM
Srikrishna
(4,280 Views)
Instead of starting a new thread, continue this question in the original thread.
(4,268 Views)
thanks!
I never realize there's an option to read line by line using read file function
Know I know 😄
(4,239 Views)
